Recent Inventions and Innovations in Induction Hardening of Gears and Gear-Like Components March 1, 2013 This paper examines the expanding capabilities of induction hardening of gears through methods like spin hardening or tooth-by-tooth techniques.Read More
My Gear Is Bigger than Your Gear March 1, 2013 Industry battles it out for World's Largest Gear title.Read More
KISSsoft Releases Software Beta February 11, 2013 The KISSsoft 03/2013 Beta Version has now been released for a test run. The final release will be available from April 8th, 2013 - just i...Read More
Okuma Discusses Advances in Software Media February 6, 2013 Do you remember using paper tape with your CNC control? If you’ve been in the machine tool industry for a while, you may remember t...Read More
KISSsoft Welcomes MSC Software as Technology Partner February 1, 2013 KISSsoft recently announced that it will be MSC Software's first Technology Partner with a connection to the new Adams/Machinery prod...Read More
Dontyne Develops Convoloid Analysis Software January 4, 2013 Dontyne Systems has entered into an agreement with Genesis Partners to develop software for the tooth contact analysis of their Convoloid...Read More
The Involute Curve January 1, 2013 Although gears can be manufactured using a wide variety of profiles, the involute curve is the most commonly used. Here are some of the basics.Read More
Large Pinions for Open Gears - The Increase of Single Mesh Load January 1, 2013 This paper introduces mandatory improvements in design, manufacturing and inspection - from material elaboration to final machining - with special focus on today's large and powerful gearing.Read More
Gear Material Selection and Construction for Large Gears January 1, 2013 A road map is presented listing critical considerations and optimal use of materials and methods in the construction of large gears.Read More
Measurement of Involute Master January 1, 2013 Our experts tackle the topic of measuring involute masters, including both master gears and gear inspection artifacts.Read More
