This report discusses grain size and its influence on metallurgical properties including its effect on yield strength, ultimate strength, fatigue strength, and fracture toughness. Also discussed are manufacturing issues such as heat treatment, hardenability, and machinability.
The properties of both shot-peened and cold rolled PM gears are analyzed and
compared. To quantify the effect of both manufacturing processes, the tooth root
bending fatigue strength will be evaluated and compared to wrought gears.
