Faithful Addendum readers are accustomed to finding upbeat, whimsical and oddball stories about gears in this
space. What follows is not about gears, exactly. Rather, it is, as opposed to the usual bleak news about America losing its manufacturing mojo—a look at a positive, hopeful development in that regard.
