The efficient and reliable transmission of mechanical power continues, as always, to be a central area of concern and study in mechanical engineering. The transmission of power involves the interaction of forces which are transmitted by specially developed components. These components must, in turn, withstand the complex and powerful stresses developed by the forces involved. Gear teeth transmit loads through a complex process of positive sliding, rolling and negative sliding of the contacting surfaces. This contact is responsible for both the development of bending stresses at the root of the gear teeth and the contact stresses a the contacting flanks.
This is the fourth and final article in a series exploring the new ISO 6336 gear rating standard and its methods of calculation. The opinions expressed herein are those of the author as an individual. They do not represent the opinions of any organization of which he is a member.
May 18-21. AGMA Annual Meeting, "The Changing World of Gears." Loews Ventana Canyon Resort, Tucson, AZ.
July 12-14, 1989. ASM international Conference on Carburizing. Sheraton Hotel & Conference Center, Lakewood, CO.
September 12-20, 1989. European Machine Tool Show, Hannover, West Germany.
