White Papers
The following white papers have been presented by Gear Technology advertisers.
WHITE PAPER | 2026-04-23
Maximizing Gear Manufacturing Performance
Download the whitepaper to learn how lifecycle management improves tool performance, reduces downtime, and drives measurable cost savings.
WHITE PAPER | 2026-03-20
Automatic Tool Change System for Profile Grinding of Gears
This white paper explores how the use of an automatic tool change system can boost productivity in the grinding process. When manufacturing large gears, the demands regarding surface quality of the ground tooth flanks are increasing.
WHITE PAPER | 2025-11-04
Pit LPC: Upgrading the Carburizing Process with Low Pressure Carburizing
Discover how SECO/WARWICK’s PIT-LPC furnace cuts cycle times by 60%, doubles throughput, and eliminates CO₂ emissions. Learn how vacuum carburizing redefines performance, safety, and sustainability in large-part heat treatment.
WHITE PAPER | 2025-08-27
Smart(er) Move
CNC Gear Machine Tools: The Strategic Case for Re-controlling AND Re-building Versus New
WHITE PAPER | 2025-07-09
Load Spectra in the FVA-Workbench
Oversized drivetrains are inefficient and waste resources. The FVA-Workbench helps you turn real-world load data into actionable insights in just a few steps. Discover how intuitive workflows lead to lighter, safer, and more efficient drivetrains.
WHITE PAPER | 2025-03-26
Machine Learning Model-Based Minimization of Roughness Variations after Profile Grinding of Wind Power Gears
Discover how machine learning minimizes roughness variations in profile grinding, enhancing the performance and durability of wind power gearboxes. The latest research by KAPP NILES demonstrates an optimized dressing process that improves surface quality on tooth flanks after profile grinding for next-generation wind turbines.
WHITE PAPER | 2024-10-10
Over 60 years, engineers have relied on Spiroid® gearing.
From robotics to aerospace, our gears provide the most compact, highest torque and customizable solutions on the planet. It’s the perfect balance of torque, efficiency and ratio flexibility.
WHITE PAPER | 2024-08-01
The “Differential Difference” in E-Drives
Gleason's Coniflex® Pro Design and Manufacturing System for producing stronger, quieter, and more reliable e-drive differential gears in high volumes, for automotive, truck, bus and off-highway transmissions. It‘s the differential difference!
WHITE PAPER | 2024-07-15
GRSL Quality Center: The Fastest Way to Quieter Gears
Today, manufacturers take about 30 minutes to inspect and analyze a gear for NVH gear noise. Instead, the new GRSL Quality Center featuring laser inspection, optional roll testing, and Advanced Waviness Analysis for gear noise evaluation, gauges, measures and analyzes one gear in one minute, for up to 100% quality inspection of your production output.
WHITE PAPER | 2024-05-23
4D High Pressure Gas Quenching vs. Press Quenching
SECO/VACUUM’s 4D High Pressure Gas Quench (HPGQ) offers superior distortion control compared to press quenching. Both processes quench one part at a time, but the 4D HPGQ process avoids inconsistencies of liquid press quenching.
WHITE PAPER | 2024-04-30
WENZEL brings Quality and Accuracy to your team, every time.
WENZEL’s WM | Quartis software suite ensures that specializations and information silos will be a thing of the past. Whether your team is measuring on a CMM or GMM, ensure that every user seamlessly shares data across the entire plant, speeding communications and improving efficiency with this singular collection point.
WHITE PAPER | 2024-04-24
NVH Optimization and Production Tolerances
Resource efficiency and environmental protection are becoming increasingly important in modern transmission development processes, especially minimizing the CO2 footprint. These factors are critical for complying with regulatory limits and remaining competitive in a challenging market.
WHITE PAPER | 2024-02-09
Insights on Atmospheres for Heat Treating Equipment
Surface Combustion is a leader in controlled atmosphere heat treating furnaces and atmosphere generators. Learn detailed information about heat treat atmospheres including, descriptions, compositions, generation methods, and applications. This is a fantastic resource for heat treat operators, metallurgists, and maintenance technicians
WHITE PAPER | 2023-12-13
The Differential Difference!
Introducing Gleason's new Coniflex® Pro Design and Manufacturing System for producing stronger, quieter, and more reliable e-drive differential gears in high volumes, for automotive, truck, bus and off-highway transmissions. It‘s the differential difference!
WHITE PAPER | 2023-08-08
Atmospheres For Heat Treating Equipment
Surface Combustion is a leader in controlled atmosphere heat treating furnaces and atmosphere generators.  Learn detailed information about heat treat atmospheres including, descriptions, compositions, generation methods, and applications. This is a fantastic resource for heat treat operators, metallurgists, and maintenance technicians. Contact Surface Combustion to discuss your specific requirement.
Next Step in Nano Level Inspection
Gleason’s new 175GMS® nano Gear Metrology System is built for today’s unprecedented transmission noise challenges and tooth form quality requirements. 175GMS nano delivers sub-micron analysis of tooth surface roughness after polish grinding; applies Advanced Waviness Analysis tools to detect and mitigate critical noise behavior caused by hard-to-find tooth form irregularities.
WHITE PAPER | 2023-02-06
Case Hardening Options for Heat Treating Steel
Uncover the processes and furnaces used for the steel case hardening solutions. Ben Bernard from Surface® Combustion, Inc. describes these options and reveals the advantages and disadvantages of the various options.
WHITE PAPER | 2022-12-19
Low Temperature Process Options to Reduce Gear Distortion in Thermal Processing
Ferritic Nitrocarburizing (FNC) and Nitriding improve wear, corrosion, and fatigue properties by processing in furnaces at lower temperatures while minimizing distortion. Learn more from Ben Bernard at Surface® Combustion, Inc.
WHITE PAPER | 2022-12-13
Low Pressure Carburizing of Gears
Solar Atmospheres provides low pressure carburizing (LPC) that significantly increases the surface hardness/strength of steel parts for improved friction and wear. Performing LPC in a vacuum furnace results in clean parts with less distortion reducing post process finishing operations, and costs.
WHITE PAPER | 2022-10-31
Inspection at Nano Level
Gleason’s new 300GMS nano Gear Metrology System is built for today’s unprecedented transmission noise challenges and tooth form quality requirements. Transmission noise challenges? Go nano.
WHITE PAPER | 2022-09-20
The Power of Knowledge—The Key to Success with Power Skiving
A number of beneficial factors have made skiving an attractive process for the series production of gears.
WHITE PAPER | 2022-09-19
Liebherr: development and innovation in gear technology
In the newest edition of their customer magazine Evotion, Liebherr presents industry-qualified solutions for even niche challenges, bridging the divide between proven gear technologies and modern automation solutions, between traditional mechanical engineering and Industry 4.0.: read about the LHReportInfo, the new app for networked production and more.
