Sponsored Content
The following sponsored content have been presented by Gear Technology advertisers.
WHITE PAPER | 2026-04-23
Maximizing Gear Manufacturing Performance
Download the whitepaper to learn how lifecycle management improves tool performance, reduces downtime, and drives measurable cost savings.
WHITE PAPER | 2026-03-20
Automatic Tool Change System for Profile Grinding of Gears
This white paper explores how the use of an automatic tool change system can boost productivity in the grinding process. When manufacturing large gears, the demands regarding surface quality of the ground tooth flanks are increasing.
WEBINAR | 2026-02-04
Our Cobots Debur Their Own Gears – How We Automated Our Worst Shop Job
Join Kevin Meister and Troy Kirby from Productive Robotics,  for a practical look at moving from hand deburring to cobot-automated in their own facility and many others.
SPONSORED CONTENT | 2025-12-09
Advanced Diagnostic Tools Optimize RX® Endothermic Gas Atmosphere Generator Operations
Discover four diagnostic enhancement tools that move RX® endothermic gas atmosphere generator operations from preventative to predictive maintenance. Learn how monitoring dew point by retort, comparing equal flow, tracking tube performance, and measuring outlet temperatures prevent costly failures while ensuring consistent, high-quality carrier gas production.
WHITE PAPER | 2025-11-04
Pit LPC: Upgrading the Carburizing Process with Low Pressure Carburizing
Discover how SECO/WARWICK’s PIT-LPC furnace cuts cycle times by 60%, doubles throughput, and eliminates CO₂ emissions. Learn how vacuum carburizing redefines performance, safety, and sustainability in large-part heat treatment.
SPONSORED CONTENT | 2025-10-07
Precision Gearing Solutions Engineered for Advanced Mechanical Systems
Spiroid Gearing delivers precision gearing for advanced mechanical systems engineered to handle extreme torque and complex motion requirements. With unique right-angle gear solutions, our technology enhances efficiency, reliability, and design flexibility. This empowers engineers to push boundaries in aerospace, defense, robotics, and industrial applications where performance and durability are non-negotiable.
WHITE PAPER | 2025-08-27
Smart(er) Move
CNC Gear Machine Tools: The Strategic Case for Re-controlling AND Re-building Versus New
SPONSORED CONTENT | 2025-08-18
Cost Considerations and Investment Strategies for In-House Heat Treating
Setting up an in-house heat treating operation allows businesses throughout many industries to harness this powerful technology and create better-quality metal parts. In this article, Surface Combustion discusses the biggest cost considerations involved in purchasing in-house heat treating technology and investment strategies to ensure you maximize your ROI.
SPONSORED CONTENT | 2025-08-06
Nano-Level Gear Inspection
With the introduction of the new 175GMS nano Gear Metrology system, Gleason brings its renowned “nano” sub-micron level inspection capabilities to smaller gears, helping ensure minimal noise, greater precision, and longer life.
SPONSORED CONTENT | 2025-07-23
Any Application. Any Material. Any Gear.
Design, material selection, prototyping, serial production. No matter the application, temperature, load, gear quality, or complexity, Gleason Plastic Gears is your one-stop partner for precision polymer gears and housings.
WHITE PAPER | 2025-07-09
Load Spectra in the FVA-Workbench
Oversized drivetrains are inefficient and waste resources. The FVA-Workbench helps you turn real-world load data into actionable insights in just a few steps. Discover how intuitive workflows lead to lighter, safer, and more efficient drivetrains.
SPONSORED CONTENT | 2025-05-08
What's keeping you up at night?
From countless conversations with folks running gear operations, we know you're probably focused on..."
SPONSORED CONTENT | 2025-04-21
Inject Mold Paper
Injection molding bridges prototyping and full-scale production with its unmatched scalability and precision. By integrating CT technology, manufacturers gain clear insights into mold accuracy and material behavior—accelerating the path from design to high-volume, defect-free plastic parts.
SPONSORED CONTENT | 2025-04-18
Gears for Robotics: We Have You Covered
Whether it’s gears for industrial or humanoid robots, Gleason has you covered:
100PS Power Skiving and Hobbing Machine and Phoenix® 100C Bevel Gear Cutting Machine provide excellent productivity and flexibility to cut your strain wave and planetary gears, as well as bevel and hypoid gear sets in unsurpassed quality. Both come with or without integrated automation and complete tooling systems. Measure the results on the 175GMS nano Metrology System with various analysis capabilities.
SPONSORED CONTENT | 2025-04-09
Boost Productivity & Cut Costs with a Free WPS Evaluation
Is your grinding or finishing process optimized for maximum efficiency? The Weiler Process Solutions (WPS) evaluation helps gear manufacturers to enhance productivity, reduce costs, and improve safety. Our expert team will assess your operation and recommend tailored solutions to optimize performance. Sign up for a free evaluation today, and we’ll contact you within 48 hours to discuss how we can help—potentially visiting your site for a hands-on assessment.
WHITE PAPER | 2025-03-26
Machine Learning Model-Based Minimization of Roughness Variations after Profile Grinding of Wind Power Gears
Discover how machine learning minimizes roughness variations in profile grinding, enhancing the performance and durability of wind power gearboxes. The latest research by KAPP NILES demonstrates an optimized dressing process that improves surface quality on tooth flanks after profile grinding for next-generation wind turbines.
SPONSORED CONTENT | 2025-03-14
Elevate Your Grinding Operations at AISTech 2025
 Join us at AISTech, Booth 1161, where our abrasives experts will help you to unlock your full potential. You will learn about Precision Express, our latest innovative service that combines on-demand profiling with readily available grinding wheels, cutting your lead times from months to just days. For those who value productivity-enhancing solutions and want a competitive edge, Weiler Abrasives is a premier partner.
SPONSORED CONTENT | 2025-02-24
See the Big Picture for Small Gears
New Phoenix® 100C Bevel Gear Cutting Machine for dry and wet cutting of straight and spiral bevel gears up to 100 mm (3.94”) OD combines maximum productivity and quality with ease of operation and minimum floorspace – with or without integrated automation. Complemented by the intuitive GEMS® HMI, precision workholding, and different cutter systems, it lets you focus on the big picture.
SPONSORED CONTENT | 2025-02-10
Automated Allcase® Atmosphere BIQ Heat Treat Lines by Surface Combustion
Automation in heat treating yields more consistent results with greater utilization. Surface Combustion has automated heat treat lines for batch processing.  The automated production cell using the Allcase® atmosphere batch integral quench furnace is a great option for automating the harden, quench and temper processes.
SPONSORED CONTENT | 2025-01-31
Revolutionize Your Gear Grinding Operations
Partner with Weiler Abrasives and experience fast, reliable service. Precision Express combines in-house profiling with on-hand stock, reducing lead times from months to days. Whether it’s a sudden demand or custom profiles, we ensure consistent availability, on-time delivery, and a hassle-free experience, so you can focus on exceptional results.
SPONSORED CONTENT | 2024-12-02
Solar Atmospheres Nadcap Oil Quenching Capabilities
Solar Atmospheres Nadcap accredited vacuum oil quench thermal processing with a 36” x 36” x 48” vacuum oil quench furnace, capable of safely quenching 2,000-pound loads without carbon potential concerns. Processing materials under a protective atmosphere with an oil quench, providing precise results and repeatability.
SPONSORED CONTENT | 2024-11-27
Automating Gear Production: EMAG’s All-in-One Planetary Gear Solutions
Traditionally, the process chain for manufacturing planetary gears consists of four steps: turn the blank; rough machine the tooth profiles; harden the gears; and follow with hard finishing. Whether producing gears for gasoline-powered or electric-driven gear boxes, EMAG provides automated, gear manufacturing solutions from a single source
WHITE PAPER | 2024-10-10
Over 60 years, engineers have relied on Spiroid® gearing.
From robotics to aerospace, our gears provide the most compact, highest torque and customizable solutions on the planet. It’s the perfect balance of torque, efficiency and ratio flexibility.
WEBINAR | 2024-08-29
Leveraging Simmerring® Seals for Better Performance
Join Freudenberg’s webinar to explore sealing innovations tailored for gearbox efficiency. Learn how our seals combine tradition with cutting-edge technology, setting new industry benchmarks.
SPONSORED CONTENT | 2024-08-09
Gear Grinding Doesn’t Need to be so Difficult
Elevate your gear grinding operations at IMTS 2024. Join us at Booth 237253 to learn how you can optimize your abrasives consumables’ operating costs with support from Weiler Process Solutions (WPS) and Precision Express.
Versatile Profile Grinder for Gears, Worms & Splines
Grind spur, helical and crown gears, worms, splines, ball screws, rotors for air compressors and screws for hydraulic pumps on the EMAG SU’s G 375 H. Its customizable options can grind high-quality workpieces up to 15” diameter and 34.5” long.
WHITE PAPER | 2024-08-01
The “Differential Difference” in E-Drives
Gleason's Coniflex® Pro Design and Manufacturing System for producing stronger, quieter, and more reliable e-drive differential gears in high volumes, for automotive, truck, bus and off-highway transmissions. It‘s the differential difference!
WHITE PAPER | 2024-07-15
GRSL Quality Center: The Fastest Way to Quieter Gears
Today, manufacturers take about 30 minutes to inspect and analyze a gear for NVH gear noise. Instead, the new GRSL Quality Center featuring laser inspection, optional roll testing, and Advanced Waviness Analysis for gear noise evaluation, gauges, measures and analyzes one gear in one minute, for up to 100% quality inspection of your production output.
WHITE PAPER | 2024-05-23
4D High Pressure Gas Quenching vs. Press Quenching
SECO/VACUUM’s 4D High Pressure Gas Quench (HPGQ) offers superior distortion control compared to press quenching. Both processes quench one part at a time, but the 4D HPGQ process avoids inconsistencies of liquid press quenching.
WHITE PAPER | 2024-04-30
WENZEL brings Quality and Accuracy to your team, every time.
WENZEL’s WM | Quartis software suite ensures that specializations and information silos will be a thing of the past. Whether your team is measuring on a CMM or GMM, ensure that every user seamlessly shares data across the entire plant, speeding communications and improving efficiency with this singular collection point.
WHITE PAPER | 2024-04-24
NVH Optimization and Production Tolerances
Resource efficiency and environmental protection are becoming increasingly important in modern transmission development processes, especially minimizing the CO2 footprint. These factors are critical for complying with regulatory limits and remaining competitive in a challenging market.
WHITE PAPER | 2024-02-09
Insights on Atmospheres for Heat Treating Equipment
Surface Combustion is a leader in controlled atmosphere heat treating furnaces and atmosphere generators. Learn detailed information about heat treat atmospheres including, descriptions, compositions, generation methods, and applications. This is a fantastic resource for heat treat operators, metallurgists, and maintenance technicians
WHITE PAPER | 2023-12-13
The Differential Difference!
Introducing Gleason's new Coniflex® Pro Design and Manufacturing System for producing stronger, quieter, and more reliable e-drive differential gears in high volumes, for automotive, truck, bus and off-highway transmissions. It‘s the differential difference!
SPONSORED CONTENT | 2023-12-01
Low Pressure Carburizing of Gears
Solar Atmospheres provides low pressure carburizing (LPC) that significantly increases the surface hardness/strength of steel parts for improved friction and wear. Performing LPC in a vacuum furnace results in clean parts with less distortion reducing post process finishing operations, and costs.
WHITE PAPER | 2023-08-08
Atmospheres For Heat Treating Equipment
Surface Combustion is a leader in controlled atmosphere heat treating furnaces and atmosphere generators.  Learn detailed information about heat treat atmospheres including, descriptions, compositions, generation methods, and applications. This is a fantastic resource for heat treat operators, metallurgists, and maintenance technicians. Contact Surface Combustion to discuss your specific requirement.
Next Step in Nano Level Inspection
Gleason’s new 175GMS® nano Gear Metrology System is built for today’s unprecedented transmission noise challenges and tooth form quality requirements. 175GMS nano delivers sub-micron analysis of tooth surface roughness after polish grinding; applies Advanced Waviness Analysis tools to detect and mitigate critical noise behavior caused by hard-to-find tooth form irregularities.
WHITE PAPER | 2023-02-06
Case Hardening Options for Heat Treating Steel
Uncover the processes and furnaces used for the steel case hardening solutions. Ben Bernard from Surface® Combustion, Inc. describes these options and reveals the advantages and disadvantages of the various options.
WHITE PAPER | 2022-12-19
Low Temperature Process Options to Reduce Gear Distortion in Thermal Processing
Ferritic Nitrocarburizing (FNC) and Nitriding improve wear, corrosion, and fatigue properties by processing in furnaces at lower temperatures while minimizing distortion. Learn more from Ben Bernard at Surface® Combustion, Inc.
WHITE PAPER | 2022-12-13
WHITE PAPER | 2022-10-31
Inspection at Nano Level
Gleason’s new 300GMS nano Gear Metrology System is built for today’s unprecedented transmission noise challenges and tooth form quality requirements. Transmission noise challenges? Go nano.
WHITE PAPER | 2022-09-20
The Power of Knowledge—The Key to Success with Power Skiving
A number of beneficial factors have made skiving an attractive process for the series production of gears.
WHITE PAPER | 2022-09-19
Liebherr: development and innovation in gear technology
In the newest edition of their customer magazine Evotion, Liebherr presents industry-qualified solutions for even niche challenges, bridging the divide between proven gear technologies and modern automation solutions, between traditional mechanical engineering and Industry 4.0.: read about the LHReportInfo, the new app for networked production and more.
WEBINAR | 2021-08-26
Take Off Into the New Era of Industry 4.0-Based Condition Monitoring
Want to improve reliability, productivity and profitability in your manufacturing operations? Register for this free webinar to learn how Industry 4.0-based condition monitoring systems, such as OPTIME from Schaeffler, can prevent unplanned machine downtime. Experience cutting-edge technology that can monitor your balance of plant assets across entire manufacturing facilities – seamlessly, cost-effectively and completely automatically!
