Resonant response
Taxes may be one of the only two sure things in life, but that doesn't make them popular. Nobody is happy to pay them, and the bigger the amount due, the unhappier the taxpayer. Conversely, politicians know that coming out in favor of a tax cut is the equivalent of voting for apple pie and motherhood. It's a sure-fire success at the ballot box.
From tiny beginnings, the AGMA Gear Expo is growing into a fine, strapping show. This year's effort, Gear Expo '89, "The Cutting Edge," will be bigger and better than ever. What started as a few tabletop exhibits in Chicago four years ago has now grown to a full-size, international exhibition at the David Lawrence Convention Center in Pittsburgh. With over 160 exhibitors, including major gear manufacturers and suppliers from around the world, this year's show promises to be a great success as well.
One of the current research
