In this article, a new tip relief profile modification for spur gears is presented. The topography proposed here is a classical linear profile modification with a parabolic fillet.
This paper discusses the influence of tip relief, root relief, load modification, end relief and their combinations on gear stresses and transmission errors due to shaft deflections.
Combining involute curves and body curves, merging factory and fashion, Winzeler Gear has transformed one of its products into gear haute couture. Winzeler Gear has created a plastic gear dress.
