At the dawn of the Industrial
years ago.
A computational fluid dynamics (CFD) method is adapted, validated and applied to spinning gear systems with emphasis on predicting windage losses.
Several spur gears and a disc are studied. The CFD simulations return good agreement with measured windage power loss.
Due to its economical efficiency, the gear shaving process is a widely used process for soft finishing of gears. A simulation technique allows optimization of the process.
