Schafer Gear Works greatly reduces gear inspection queue time and adds precious capacity by installing Gleason's
new "shop-hardened" 300GMS P gear inspection system.
I'd like to apologize to the dedicated people working on revisions to the AGMA 925 standard and the Technical Report ISO 15144-1, both of which deal with the issue of micropitting. In the
March/April issue of Gear Technology, we published an opinion piece in our Voices column that harshly criticized the methods for predicting micropitting outlined in ISO 15144-1.
In 1971, the American gear business was far different from today. I am unaware of any modern company with a formal gear cutter’s apprenticeship; at...
Plastic gears are everywhere
