Light-weight construction and consideration of available resources result in gearbox designs with high load capacity and power density. At the same time, expectations for gear reliability are high. Additionally, there is a diversity of planetary gears for different applications.
For metal replacement with powder metal (PM) of an automotive transmission, PM gear design differs from its wrought counterpart. Indeed, complete reverse-engineering and re-design is required so to better understand and document the performance parameters of solid-steel vs. PM gears. Presented here is a re-design (re-building a 6-speed manual transmission for an Opel Insignia 4-cylinder, turbocharged 2-liter engine delivering 220 hp/320 N-m) showing that substituting a different microgeometry of the PM gear teeth -- coupled with lower Young’s modulus -- theoretically enhances performance when compared to the solid-steel design.
