Tooth contact under load is an important verification of the real contact conditions of a gear pair and an
important add-on to the strength calculation according to standards such
as ISO, AGMA or DIN. The contact analysis simulates the meshing of the
two flanks over the complete meshing
cycle and is therefore able to consider
individual modifications on the flank
at each meshing position.
Easily one of the central issues
affecting U.S. manufacturing is what one might call the exports deficit—the inability of American companies to sell products to, for instance, Asian markets, developing countries and other ports of call—due to what they perceive to be unfair trade agreements and or policies.
The machine element package by KISSsoft for the design and optimization of components like gears, shafts, bearings and others is now available in the new version 04/2010.
Gear manufacturers are moving into an era that will see changes in both engineering practices and industry
standards as new end-products evolve. Within the traditional automotive
industry, carbon emission reduction
legislation will drive the need for higher levels of efficiency and growth in electric and hybrid vehicles.
Meanwhile, the fast growing market of wind turbines is already opening up a whole new area of potential for gearbox manufacturers, but this industry is one that will demand reliability, high levels of engineering excellence and precision manufacturing.
Gear engineers have long recognized the importance of considering system factors when analyzing a single pair of gears in mesh. These factors include important considerations
such as load sharing in multi-mesh geartrains and bearing clearances, in addition to the effects of flexible components such as housings, gear blanks, shafts and carriers for planetary geartrains. However, in recent years, transmission systems have become increasingly complex—with higher numbers of gears and components—while the quality requirements and expectations in terms of durability, gear whine, rattle and efficiency
have increased accordingly.
A computational fluid dynamics (CFD) method is adapted, validated and applied to spinning gear systems with emphasis on predicting windage losses.
Several spur gears and a disc are studied. The CFD simulations return good agreement with measured windage power loss.
