Gear Technology was founded 22 years ago on a very simple principle: to provide the best possible educational articles and information for the gear industry.
Hobs, broaches, shaper cutters,
shaver cutters, milling cutters,
and bevel cutters used in the
manufacture of gears are commonly
made of high speed steel. These specialized gear cutting tools often require properties, such as toughness or manufacturability, that are difficult to achieve with carbide, despite the developments in carbide cutting tools for end mills, milling cutters, and tool inserts.
Flexibility and productivity are the keywords in today’s grinding operations. Machines are becoming
more flexible as manufacturers look
for ways to produce more parts at a
lower cost. What used to take two
machines or more now takes just one.
To meet the future goals of higher productivity and lower production costs, the cutting speeds and feeds in modern gear hobbing applications have to increase further. In several cases, coated carbide tools have replaced the commonly used high speed steel (HSS) tools.
Load-carrying capacity of gears, especially the surface durability, is influenced by their tooth surface
roughness in addition to their tooth profiles and tooth traces.
