The two ZFA series gear grinders are designed to perform high-speed and high-precision finish machining on gears. The two models are each designed for a different gear size range, with ZFA160 capable of handling gears with an external diameter of up to 160 mm, and ZFA260 accommodating gears with an external diameter of up to 260 mm. Capable of meeting the increasingly sophisticated users’ needs, both ZFA160 and ZFA260 can mass-produce gears with a gear accuracy level equivalent to ISO 3 (JIS level N3).
Since I have had the privilege of visiting numerous gear plants and research centers in the U.S., as well as 170 in 33 countries, and I closely watch the progression of technology, I wanted to share my observations about some technological advancements. For the purpose of this article, I will focus on three key areas: Robotics, Machine Tools, and Heat Treating.
Machine Tool Builders has added highly experienced sales professional and machine tool industry veteran Ross Wegryn-Jones to its national sales organization.
Starting a career is something special for every young person. In August 2024, Klingelnberg once again welcomed 22 young apprentices who started their training in various professions. During the orientation week in early August 2024, the trainees had the opportunity to demonstrate their teamwork skills in the climbing park in Hückeswagen, Germany, attend a first aid course, and learn about the company’s values.
At AMB 2024 in Stuttgart, ANCA recently presented a range of innovations and partner solutions. From blank to a finished high-quality tool, all on one machine – ANCA’s ultimate single setup solution for complete machining of cutting tools, including blank preparation, was shown on the MX7 Ultra. This technology ensures a seamless process that optimizes efficiency and productivity, allowing you to manufacture a wide range of tools below 0.2 Ra with reduced cycle time.
Unisig’s next-generation operating system further improves the human-robot interface and slashes programming times. The new operating system, featured on Unisig’s UNE6-2i-750-CR small-diameter gundrilling machine, streamlines the setup of dozens of different part handling combinations to reduce new part setup times by 80% or more. The system significantly improves the communication between the machine’s human machine interface (HMI) and the robotic controller. This enables centralized data storage or a single source of truth -– the coding and data for the gundrilling operation and the program for the part handling are stored together for ease of recall.
With the new Automated Tool Production (ATP) system, Walter now offers a comprehensive automation solution for cutting tools. ATP networks grinding, eroding and measuring machines from Walter, as well as upstream and downstream machines from other system partners in the production process.
In 2023, Bourn & Koch and Mollart Machinery were both welcomed into the InCompass™ portfolio through two acquisitions completed just days apart. To leverage the strengths of both organizations, Mollart Machinery's production operations and field service support, previously based in Chessington, United Kingdom, will be based out of Bourn & Koch's facility in Rockford, IL, USA. Ongoing support from Mollart's headquarters in Chessington will ensure a seamless transition.
As the automotive industry continues to move towards e-mobility, the manufacturing world is adapting to the respective requirements. Large gear ratios are necessary to reduce the high input speeds of electric motors to the required speed of the drive wheels. At the same time, masking noise of combustion engines is now missing, posing challenges to the noise level of transmissions. Principally, two main transmission concepts have become established for e-drive applications: two-stage layshaft transmissions with four gears, and planetary transmissions.
The International Manufacturing Technology Show (IMTS)—September 9–14 at Chicago’s McCormick Place—is the largest manufacturing technology show and marketplace in the Western Hemisphere, and it’s right around the corner! With visitors from more than 110 countries, IMTS is where the creators, builders, sellers and drivers of manufacturing technology come to connect and be inspired. But with more than 1.2 million square feet of exhibit space, where do you begin? Here at Gear Technology, we do our best to help you make the most of your show experience by assembling booth previews that will be worthy of your attention.
