NC and CNC metal cutting machines are among the most popular machine tools in the business today, There is also a strong trend toward using flexible
machining centers and flexible manufacturing systems. The same trend is apparent in gear cutting. Currently the trend toward CNC tools has increased, and sophisticated controls and peripheral equipment for gear cutting machines are now available; however, the investment in a CNC gear machine has to be justified on the basis of economic facts as well as technical advantages.
One of the current research
This paper presents two new techniques for
aligning and maintaining large ring gears. One technique uses lubricant temperature analysis, and the other uses stop action photography.
