Tool systems for grinding and honing today’s most challenging gears
February 13, 2023
The trend towards hard fine finishing of gears for automotive transmissions is accelerating. In recent years, the focus has been on increasing the efficiency of gears in order to make optimum use of the narrow gear ratio range, gear by gear, and to reduce fuel consumption. Surface finish, in particular, is under increased scrutiny since it plays such a decisive role in achieving the noise and efficiency requirements of gear units for today’s EV applications.
In acquiring the Turkish Egeli Egesan Group the Tyrolit Group continues to implement its business expansion strategy and has further strengthened its position on the international abrasives market.
At the dawn of the Industrial
