Plastic gears are everywhere
I would like some instructions for setting the degrees and minutes on a Liebherr
or Barber Colman hob. Our machines use a Vernier scale to match the lead angle
of the cutter to the part to form straight teeth. There is a dispute on how to do
this task, and I wanted insight from another professional.
I have outsourced gear macrogeometry due to lack of resources. Now I received the output from them and one of the gears is with —0.8× module correction factor for m = 1.8 mm gear. Since bending root stress and specific slide is at par with specification, but negative correction factor —0.8× module — is quite high — how will it influence NVH behavior/transmission error? SAP and TIF are very close to
0.05 mm; how will that influence the manufacturing/cost?
