Gleason introduces the new online selector for its renowned LeCount Expanding Mandrels. Customers can now select required mandrels from Gleason’s standard range or request special LeCount mandrels with just a few clicks, including simple re-orders and certification services for mandrels in use.
Gleason LeCount Adjustable Expanding Mandrels offer a fast, flexible and amazingly simple solution for metrology applications where speed, accuracy and repeatability are paramount
Keep it simple. More often than not it turns out to be the best course of action in life and on factory floors. Take, for example, Gleason LeCount Expanding Mandrels. You’ll find them in quality labs around the world, delivering reliable, repeatable workholding performance for the inspection of gears and other bore-type workpieces. Quality labs today are at the epicenter of the drive to produce increasingly complex, high-precision parts, while at the same time racing to take time and cost out of the inspection process. Counter-intuitively, perhaps, the best workholding solution to meet these ambitious new inspection requirements turns out not to be something new and more complex—but the simplest solution of all: Gleason LeCount Expanding Mandrels.
Dillon Manufacturing’s Claw Jaws have an optimized contour which provides a secure grip on the workpiece, and the jaws weight, center of gravity and cutting forces combine to minimize jaw clamping force loss.
SMW Autoblok presents the BB-FZA2G pneumatic 3+3 sequencing air chuck featuring an extended stroke clamping range and three self-centering jaws with axial adjustment.
