Hexagon Examines Capturing Quality Data Across the Value Chain
January 20, 2025
A connected, holistic approach to quality is perhaps the biggest opportunity to win an advantage over your competitors. We need to make sure we have the right data, in the correct context, shared with the right people in a timely fashion. Without data we are just guessing, stumbling around in the dark. Data is like vision. Without it we are blind.
With the recent software release Zeiss Industrial Quality Solutions (Zeiss IQS) enhances its extensive software portfolio, introducing cutting-edge innovations in multiple software products to optimize inspection processes and streamline data handling capabilities.
Zahnradfertigung OTT GmbH & Co. KG was the first company to install the new fully automatic CNC-controlled P 152 precision measuring center from Klingelnberg in its ultra-modern machine park.
Mitutoyo America Corporation, a leader in precision measuring instruments, is excited to announce the integration of the powerful Metlogix M3 software into the Mitutoyo Quick Image (QI) 2D Vision Measuring System. This latest enhancement promises to elevate the precision and efficiency of noncontact measurements, further solidifying Mitutoyo’s commitment to providing innovative technology solutions to meet modern quality control needs.
Rego–Fix, a Swiss toolholding company and inventor of the standard-setting ER collet, has partnered with tool measuring and management solution company Omega TMM for the creation of Orion powered by Rego–Fix – a tool measuring machine using REGO–FIX’s powRgrip toolholding system with Omega TMM’s presetting technology.
All 34 portable measuring arms offered in 6-axis touch-probing and 7-axis multi-sensor variants by LK Metrology, Castle Donington, are now supplied as standard with a 4.5 in. diameter mounting ring to allow the unit to sit on a larger base, rather than that provided by the previous 3.5 in. ring. The result of having this extra stability is that the new Version 3 Freedom Arms are capable of measuring to higher precision. A mounting ring adapter can be supplied if an existing user already owns an LK tripod or stand with a 3.5 in. mount. Mechanical, magnetic and vacuum fixing alternatives are available.
Mahr MWF GmbH has developed and built a measuring machine for double-flank gear roll testing to meet the individual requirements of a customer. This machine tests the form feature concentricity deviation Fr on the internal toothing of gears. The noise development of the subsequent gearbox can then be predicted based on the measurement results. This is an important aspect, particularly in electromobility.
Rego-Fix has launched a new online product-finder resource, which allows U.S. manufacturers to quickly and easily find and purchase the Rego-Fix solution that best meets their application needs. Using a variety of search criteria, users can find and learn more about the full lineup of products.
Zeiss and CleanControlling, a leading test laboratory for technical cleanliness, signed a cooperation agreement in April. The goal of the cooperation is to optimize products and industrial analysis techniques, and to set new market standards.
With the 175GMS nano, Gleason brings submicron-level inspection capabilities to smaller gears, helping ensure minimal noise, greater precision, and longer life
Complete inspection of gear surface finishes at the submicron level became a reality with the introduction of Gleason’s 300GMS nano, in 2022. The new system ushered in an exciting new era in gear inspection. For the first time, producers of EV transmission gears, and gears for other applications requiring very tight tolerances and low noise requirements, could quickly inspect surface finishes and perform extremely reliable noise analysis at submicron levels—benefits that were almost impossible to achieve just a few years ago.
