The latest news from GKN, Milan Manufacturing, Solar Atmospheres, Heidenhain, Furnaces North America, Gleason, Haas Multigrind, Schunk and Michigan Metrology
Due to production by pressing and sintering, PM gears are porous. Since pores reduce the loaded area and are also probable crack initiators, the porosity determines the strength of the PM component. PM gears can be densified to increase their local density and, therefore, the load-carrying capacity. PM gears are compacted locally since they are mainly loaded directly at the surface. A common process to densify PM gears locally is the cold rolling process. The contact conditions in the cold rolling process determine the density profile and, therefore, the material properties of the PM component. The influence of the contact conditions in cold rolling of PM gears on the resulting density profile is yet to be investigated.
Gear inspection has long been a highly specialized costly investment and an overall challenging part of the gear manufacturing process. Given that complicated gages, testers, and CNC equipment all go into creating high quality gears, companies may want to invest in a CMM to streamline inspection.
