I would like some instructions for setting the degrees and minutes on a Liebherr
or Barber Colman hob. Our machines use a Vernier scale to match the lead angle
of the cutter to the part to form straight teeth. There is a dispute on how to do
this task, and I wanted insight from another professional.
