Suppliers are working hard to make
sure their heat treating equipment is controllable, repeatable and efficient,
and manufacturers continue to incorporate technology that gives heat treaters and their customers more information about what's going on inside the magic box.
Effective case depth is an important factor and goal in gas carburizing, involving complicated procedures in the furnace and requiring precise control of many thermal parameters. Based upon diffusion theory and years of carburizing experience, this
paper calculates the effective case depth governed by carburizing temperature, time, carbon content of steel, and carbon potential of atmosphere. In light of this analysis,
carburizing factors at various temperatures and carbon potentials for steels with different
carbon content were calculated to determine the necessary carburizing cycle time.
This methodology provides simple (without computer simulation) and practical guidance
of optimized gas carburizing and has been applied to plant production. It shows that measured, effective case depth of gear parts covering most of the industrial application range (0.020 inch to over 0.250 inch) was in good agreement with the calculation.
Square, rectangular, triangular, oval, even fish-shaped - Clayton Boyer's Weird Gears come in every shape except for circular, and they all work. If you're interested in giving them a gander, check out Boyer's Youtube video (just search "weird gears" and it'll be right there
at the top) to see them in motion
