You get one shot to make a first impression. One opportunity to show your customers, vendors and suppliers that you provide a steady, reliable product that will generate repeat business. How do you make this happen? What tools and strategies are available to get gear materials (forgings, gear blanks, etc.) shipped faster and more efficiently in today's tech-heavy, fast-paced, manufacturing environment?
Broaching is a machining technique commonly used to cut gear teeth or cam profiles for the high volume manufacture of power transmission parts used in vehicles (Refs. 1–2). This article shows how the right gear blank material can make all the difference if you want to get more parts out of each tool.
The process of forging metal into shapes possesses
a surprisingly long and storied history.
For example, the method of hot rolling can trace its protracted existence all the way back to an enigmatic Italian polymath named Leonardo da Vinci (you may have heard of him), who reportedly invented the rolling mill one lazy day in the 1400s.
