AGMA is happy to announce the publication of two new documents: AGMA 925-B22, Effect of Tribology and Lubrication on Gear Surface Distress, written by a subcommittee of the AGMA Helical Gear Rating Committee, and, AGMA 943-A22, Tolerances for Spur and Helical Racks, written by the AGMA Gear Accuracy Committee.
and macropitting is examined.
