Carbon steels have primarily been used to manufacture aerospace gears due to the steels' mechanical characteristics. An alloyed low carbon steel is easily case-hardened to obtain a hard wear surface while maintaining the ductile core characteristics. The microstructure achieved will accept the heavy loading, shocks, and elevated temperatures that gears typically experience in applications. The carbon steel machinability allows for general machining practices to be employed when producing aerospace gears versus the more advanced metal removal processes required by stainless and nickel-based alloys.
Gear manufacturers typically use plastic, steel or other metals to make their gears, but Andrew Shotts made his first gears out of sugar and chocolate.
Top Secret
Code Name: Ginger
Mission: Design, prototype and test a transmission for a new device. The transmission must be compact and efficient. It should have almost no backlash, and it must be able to operate in both forward and reverse. Most importantly, the transmission must be quiet. In fact, it shouldn't sound like a transmission at all. It should blend in with the environment and sound like music or the wind. This mission, should you choose to accept it, is top secret. Not even your employees can know what you're working on...
If you think of Gear Expo as only a machine tool show, you're not seeing all of its potential. You may be tempted to skip it this year, especially if you're struggling to fill your current capacity. I've heard too many stories of canceled orders, falling profits and slashed budgets to believe that great numbers of you will be attending Gear Expo with buying new machines as your No. 1 priority.
