What's the perfect vacation destination for a gear aficionado? Aspen? Too trendy. Miami? Too humid. For a true machinery enthusiast, the perfect vacation is a gear museum road trip.
This paper reviews the necessity for detailed specification, design and manufacture to achieve required performance in service. The precise definition of duty rating and a thorough understanding of the environmental conditions, whether it is in a marine or industrial application, is required to predict reliable performance of a gearbox through its service life. A case study relating to complex marine gears and other general practice is presented to review the techniques used by Allen Gears to design and develop a gearbox that integrates with the requirements of the whole machinery installation. Allen Gears has considerable experience in the design of a variety of industrial and marine gears(Ref. 1,2).
The need for improved power transmissions that use gears and gearboxes with smaller overall dimensions and with lower noise generation has left manufacturing engineers searching for different methods of gear processing. This search has led to the requirement of hardened gears.
