NASA is now 3-D-printing spare parts up at the ISS (International Space Station). And in zero-gravity environments. And some of these parts are small gears and actuators, for starters. Every indication is that the list of power transmission-type parts to be converted will soon grow.
Have you ever stood on a beach at the edge of the water and felt the grains of sand dissolve from under your feet as the water recedes? No matter how hard you plant your feet or grip your toes, you can’t hold on to the sand. It just flows away right from under you.
In many ways that sand is like the knowledge and experience of our graying manufacturing workforce. It seems inevitable that much of that knowledge is being washed away.
