Look at that picture right over there on the right.
That’s one of the Bronze Wheels of Peru. Looks like a gear, doesn’t
it? If you knew nothing about it or the culture it sprang from and
just happened to see it on the street, you’d probably label it as such. So many people have had that same thought, in fact, that the set has picked up another name: the Bronze Gears of Peru.
Anyone even remotely involved with
the gear industry knows that Gear
Expo is B-I-G. Every two years, it is
an invaluable opportunity for buyers,
sellers and just-lookers to come
together and glorify gearing.
When it came to picking a personal favorite booth at Gear Expo, AGMA Vice President of Marketing Jenny Blackford donned her proverbial TAG
Heuer watch and embroidered silk apron and decided to keep her allegiance neutral.
Our goal at Gear Technology for the past 31 years
has been to bring you the best possible technical
information about gear manufacturing. We serve as the industry’s educational resource, explaining the technology not only so that you can understand
it, but also so that you can make use of it in your gear-related business.
