Lamentations continue—legitimately so—over the second-citizen status of manufacturing in the United States. The need undoubtedly continues for renewed support by government and educators for making things here once again...
Gear manufacturers typically use plastic, steel or other metals to make their gears, but Andrew Shotts made his first gears out of sugar and chocolate.
