Serial production of large gears requires a high level of quality, excellence, and continuity in production. Emphasis is placed on maximum synergy between the grinding machine, the grinding process, and the grinding wheel. After several successful trials on various Klingelnberg Höfler Rapid grinding machines carried out by Krebs & Riedel with customers in their production facilities, Krebs & Riedel has received several large orders for grinding large gears from abroad and has introduced the new premium grinding wheels with high process reliability.
A new range of UKAS-certified length and form gages, complete with holding fixture, has been introduced by coordinate measuring machine (CMM) manufacturer LK Metrology, allowing the inspection accuracy of any 3D measuring platform to be verified. The user can have greater confidence in the results of an inspection, whether for metrology or reverse engineering, long after the typical annual calibration of the measuring machine has been carried out.
New machining method opens up for turning several complex features with one tool
March 8, 2023
Sandvik Coromant, a cutting tool and tooling system specialist, has introduced a new method for turning complicated shapes and pockets with a single tool. Y-axis turning offers benefits such as reduced cycle time, improved component surface quality and more stable machining.
The latest version offers a wide range of powerful new features, from a new gear design module, to the influence of the wheel body during a complete rollover, to new display options for 3D images and animation of the gearbox kinematics in reports.
Jergens now offers two new zero-point-system (ZPS) installation choices for compact, light-duty applications. SP140 and K02 pull studs utilize pneumatics and a mechanical spring in a small package.
The speed with which someone can inspect a component using a portable, multi-axis measuring arm is increased by up to 40 percent if, instead of the part being static, it is placed on a new Freedom Index Table from LK Metrology, Castle Donington, UK.
Contact analysis can be used to calculate the transmission error and determine the profile modifications of a gear stage. In addition, a wide range of important gear-specific parameters can be calculated, such as tooth root stress, distribution of Hertzian pressure, oil film thickness, and many more.
Mitutoyo America Corporation, a leading manufacturer of precision metrology instruments and solutions, is proud to announce new versions of the IDC, IDF and IDS series of digimatic indicators and products built around these indicators such as depth and thickness gages.
Mapping the development process with SINUMERIK ONE reduces product development and time-to-market
January 16, 2023
With SINUMERIK ONE, the first digital native CNC, Siemens is driving forward digital transformation in the machine tool industry. The new controller works with software to create the machine controller and the associated digital twin from one engineering system and thus contributes to the seamless integration of hardware and software.
Exact Metrology: A Division of In-Place Machining Company and a comprehensive 3D metrology service provider and hardware sales company, has increased the capability of their Artec 3D handheld scanners with the new HD mode.
