Milling challenging materials like tough steels, stainless steels, superalloys and titanium cause built-up or notched edges and broken inserts that increase tooling costs and cause unexpected downtime.
Global metal-cutting leader Sandvik Coromant is expanding its milling offering with the new CoroMill MF80 for automotive milling applications in ISO K and ISO P materials in close to 90-degree operations with fixture constraints.
Global metal cutting leader Sandvik Coromant introduces its second generation of CoroTurn Prime B-type inserts. The new, double-sided negative insert features four cutting edges and is designed for roughing and finishing in steel, stainless and duplex stainless steel, HRSA and titanium.
Marposs, a global leader in measurement, inspection and test technologies, has announced its new M62 Laser Profiler for Gear Inspection, using laser profile sensors and the optical triangulationprinciple.
Nagel and Gehring recently shared innovative technologies during AMB 2022 including new standards in efficient honing, maximum flexibility in the superfinishing of flat, concave, and spherical surfaces, and efficient internal and external honing of workpieces.
Marposs has announced MAINDO, its new digital platform that integrates Marposs monitoring, measuring, testing or other manufacturer device/solutions throughout the entire production process, combining quality and process into a holistic production monitoring view.
Automation tasks are becoming ever more challenging. Using intelligent software in combination with the relevant automation solutions not only enables workpieces to be loaded and unloaded but also means that machine tools can be set up fully automatically through automatic replacement of tools and clamping devices. FRAI strives to be an innovative automation partner and is therefore developing highly flexible robot systems to respond to this trend. Concepts such as the mobileCELL are a complete first and enable a wide range of expansion stages, making them as future-proof and competitive as possible.
A newly developed measuring probe now allows Liebherr-Verzahntechnik GmbH the possibility of precise corrective measurement in the gear shaping machine. The measuring probe sits directly on the tool spindle and is therefore in the same coordinate system as the pinion type cutter itself. This reduces inaccuracies which might arise due to a tool change or turning a workpiece and leads to considerably higher quality and process reliability.
Renewable Lubricants presents patented, ultimately biodegradable Bio-E.P. Gear Oils which are ideal lubricating spur, helical, bevel, and worm gears subject to heavy loading or shock loading in heavy-duty applications.
GWJ Technology GmbH has extended the output option of tooth forms of involute gears. GWJ has extended the output of tooth forms in 2D DXF format in its calculation modules single cylindrical gears, cylindrical gear pairs, planetary gear trains, three- and four-gear train systems, gear racks and involute splines as part of the new versions of its calculation solutions eAssistant and TBK.
