For a long time, relatively high noise levels have been generally accepted for industrial gear units in the 10-100 kW power range. However, due to changing environmental awareness - both in and around industrial sites - customers expectations have moved drastically towards low noise as a key differentiating factor.
The grinding of gears with dish wheels (Maad type grinding machines) is widely viewed as the most precise method of gear grinding because of the very short and simple kinematic links between the gear and the tool, and also because the cutting edges of the wheels represent planar surfaces. However, in this grinding method, depending on the parameters of the gears and one of the adjustments (such as the number of teeth encompassed by the grinding wheels), so-called overtravel at the tip or at the root of the teeth being ground generally occurs. When this happens, machining with only one wheel takes place. As a result, the profile error and the length of the generating path increases while productivity decreases.
Friction weighs heavily on loads that the supporting journals of gear trains must withstand. Not only does mesh friction, especially in worm gear drives, affect journal loading, but also the friction within the journal reflects back on the loads required of the mesh itself.
Gear designers today are continually challenged to provide more power in less space and improve gear performance. The following article looks at some of the most common ways to increase the power density or improve the performance of gear trains. The author also takes an in-depth look at the case of a steel worm mating with a plastic helical gear and explores ways to optimize this increasingly common configuration.
Gear design and specification are not one and the same. They are the first two steps in making a gear. The designer sits down and mathematically defines the gear tooth, working with the base pitch of the gear, the pressure angle he wants to employ, the number of teeth he wants, the lead, the tooth thickness, and the outside, form and root diameters. With these data, the designer can create a mathematical model of the gear. At this stage, he will also decide whether the gear will be made from existing cutting tools or whether new tools will be needed, what kind of materials he will use, and whether or not he will have the gear heat treated and finished.
New innovations in the management of hear treating parts washers and yielding powerful, unexpected benefits. Simply, cost effective shop floor practices are being combined in new ways to deliver big quality improvements and significant help to the bottom line. Employing these steps early in the process can dramatically cut waste hauling expenses and greatly reduce environmental liabilities while continuously producing cleaner parts.
The efficient and reliable transmission of mechanical power continues, as always, to be a central area of concern and study in mechanical engineering. The transmission of power involves the interaction of forces which are transmitted by specially developed components. These components must, in turn, withstand the complex and powerful stresses developed by the forces involved. Gear teeth transmit loads through a complex process of positive sliding, rolling and negative sliding of the contacting surfaces. This contact is responsible for both the development of bending stresses at the root of the gear teeth and the contact stresses a the contacting flanks.
Gear noise associated with tooth surface topography is a fundamental problem in many applications. Operations such as shaving, gear grinding and gear honing are usually used to finish the gear surface. Often, gears have to be treated by a combination of these operations, e.g. grinding and honing. This is because gear honing operations do not remove enough stock although they do create a surface lay favorable for quiet operation. See Fig. 1 for typical honing process characteristics. Gear grinding processes, on the other hand, do remove stock efficiently but create a noisy surface lay.
This is the fourth and final article in a series exploring the new ISO 6336 gear rating standard and its methods of calculation. The opinions expressed herein are those of the author as an individual. They do not represent the opinions of any organization of which he is a member.
