Questions: I have heard the terms "safety factor," "service factor," and "application factor" used in discussing gear design. what are these factors an dhow do they differ from one another? Why are they important?
Question: Could you explain what is meant by "horological gearing"? I never heard of this before, although I understand it has something to do with watches. Could you also explain the meaning of a "going gear train"?
Question: When evaluating charts from a gear inspection machine, it is sometimes found that the full length of the profile traces vary, and that sometimes they are less than the length of active profile (above start of active profile-SAP) by up to 20%. This condition could be caused by a concentricity error between tooth grinding and shaping, or by unequal stock removal when grinding. (See Fig. 1.) Is it possible that some of the variation is coming from the inspection machine? How can variation from the inspection machine be reduced?
