This paper addresses the lubrication of helical gears - especially
those factors influencing lubricant film thickness and pressure.
Contact between gear teeth is protected by the elastohydrodynamic
lubrication (EHL) mechanism that occurs between nonconforming
contact when pressure is high enough to cause large
increases in lubricant viscosity due to the pressure-viscosity
effect, and changes of component shape due to elastic deflection.
Acting together, these effects lead to oil films that are stiff
enough to separate the contacting surfaces and thus prevent
significant metal-to-metal contact occurring in a well-designed
gear pair.
In terms of the tooth thickness, should we use the formulation with
respect to normal or transverse coordinate system? When normalizing
this thickness in order to normalize the backlash (backlash parameter),
we should divide by the circular pitch. Thus, when normalizing, should
this circular pitch be defined in the normal or traverse coordinate
system, depending on which formulation has been used? Is the backlash
parameter always defined with respect to the tangential plane or
normal plane for helical gears?
After a period of operation, high-speed turbo gears may exhibit a change in longitudinal tooth contact pattern, reducing full face width contact and thereby increasing risk of tooth distress due to the decreased loaded area of the teeth. But this can be tricky—the phenomenon may or may not occur. Or, in some units the shift is more severe than others, with documented cases in which shifting occurred after as little as 16,000 hours of operation. In other cases, there is no evidence of any change for units in operation for more than 170,000 hours. This condition exists primarily in helical gears. All recorded observations here have been with case-carburized and ground gear sets. This presentation describes phenomena observed in a limited sampling of the countless high-speed gear units in field operation. While the authors found no existing literature describing this behavior, further investigation suggests a possible cause. Left unchecked and without corrective action, this occurrence may result in tooth breakage.
Bringing new or improved products to
market sooner has long been proven profitable for companies. One way to help shorten the time-to-market is to accelerate validation testing. That is, shorten the test time required to validate a new or improved product.
