In this article, a new tip relief profile modification for spur gears is presented. The topography proposed here is a classical linear profile modification with a parabolic fillet.
Aerospace manufacturing has seen quite a turnaround in the past few years. The world's manufacturers of airplanes, helicopters, missiles, space vehicles and satellites are all extremely busy right now--and that's keeping quite a few gear manufacturers busy as well.
