In several applications like hoisting equipment and cranes, open gears are used to transmit power at rather low speeds (tangential velocity < 1m/s) with lubrication by grease. In consequence those applications have particularities in terms of lubricating conditions and friction involved, pairing of material between pinion and gear wheel, lubricant supply, loading cycles and behavior of materials with significant contact pressure due to lower number of cycles.
In manufacturing, we all know that
tracking statistics on your operation is
essential for understanding how you're
doing, as well as identifying areas for
improvement. But what does the efficiency
metric actually tell you?
The recent brawl in baseball reminded me that despite the ability to Google almost anything, many people are unpleasantly surprised by the “unwritt...
The purpose of this paper is to present a method of designing and specifying gear teeth with much higher bending and surface contact strength (reduced bending and surface contact stresses). This paper will show calculation procedures, mathematical solutions and the theoretical background equations to do this.
