Dear Editor:
The finished gear engineer, the man who is prepared for all emergencies, must first of all know the basic design principles.
Next he must be well versed in all sorts of calculations which come under the heading of "involute trigonometry."
Whether gear engineers have to replace an old gear which is worn out, find out what a gear's geometry is after heat treatment distortion, or just find out parameters of gears made by a competitor, sometimes they are challenged with a need to determine the geometry of unknown gears. Depending on the degree of accuracy required, a variety of techniques are available for determining the accuracy of an unknown gear. If a high degree of precision is important, a gear inspection device has to be used to verify the results. Frequently, several trial-and-error attempts are made before the results reach the degree of precision required.
When we have problems with gearset failure, a common diagnosis is misalignment. What exactly is that and how do we prevent it?
The second most common "killer" of good gear sets is misalignment (dirt, or abrasive wear, is first). Gear teeth simply won't carry the load if they don't touch, and the portion that does touch has to carry an overload to make up for the missing contact area.
