The objective of this work is to introduce a method for the calculation of the tooth root load carrying capacity for gears, under consideration of the influence of the defect size on the endurance fatigue strength of the tooth root. The theoretical basis of this method is presented in this paper as well as the validation in running tests of helical and beveloid gears with different material batches, regarding the size distribution of inclusions. The torque level for a 50 percent failure probability of the gears is evaluated on the test rig and then compared to the results of the simulation. The simulative method allows for a performance of the staircase method that is usually performed physically in the back-to-back tests for endurance strength, as the statistical influence of the material properties is considered in the calculation model. The comparison between simulation and tests shows a high level of accordance.
Although gear geometry and the design of asymmetric tooth gears are well known and published, they are not covered by modern national or international gear design and rating standards. This limits their broad implementation for various gear applications, despite substantial performance advantages in comparison to symmetric tooth gears for mostly unidirectional drives. In some industries — like aerospace, that are accustomed to using gears with non-standard tooth shapes — the rating of these gears is established by comprehensive testing. However, such testing programs are not affordable for many other gear drive applications that could also benefit from asymmetric tooth gears.
Gear designers face constant pressure to increase power density in their drivetrains. In the automotive industry, for example, typical engine torque has increased significantly over the last several decades. Meanwhile, the demands for greater fuel efficiency mean designers must accommodate these increased loads in a smaller, more lightweight package than ever before. In addition, electric and hybrid vehicles will feature fewer gears, with fewer transmission speeds, running at higher rpms, meaning the gears in those systems will have to endure life cycles far beyond what is typical with internal combustion engines.
A key part of gear design software development is customer feedback. With the right feedback, you can get your software developer to work for you to provide the most relevant features possible.
Marposs is a one-stop solutions provider for gear measurement and inspection including real-time process monitoring for gear hobbing, gear shaping and tool and profile machines. Plus, products for manual and automated gauging stations that provide dimensional, geometric and non-destruction inspection. Get exactly what you need for your application.
