Back in the days when our great, great, great, etc., grandaddies were designing gears, one of the most common materials in use was wood. For fairly obvious reasons, we don't see too many wooden gears around anymore. But there are a few.
The aim of this article is to show a practical procedure for designing optimum helical gears. The optimization procedure is adapted to technical limitations, and it is focused on real-world cases. To emphasize the applicability of the procedure presented here, the most common optimization techniques are described. Afterwards, a description of some of the functions to be optimized is given, limiting parameters and restrictions are defined, and, finally, a graphic method is described.
Resonant response
