Is it Worth Upgrading? October 16, 2018 Charles D. Schultz No Comments Read More Influence of Different Manufacturing Processes on Properties of Surface-Densified PM Gears September 1, 2018 The properties of both shot-peened and cold rolled PM gears are analyzed and compared. To quantify the effect of both manufacturing processes, the tooth root bending fatigue strength will be evaluated and compared to wrought gears.Read More Finding the Right Combination August 14, 2018 Charles D. Schultz No Comments One of the hal...Read More Planetary Gears: Inside Information July 3, 2018 Charles D. Schultz No Comments The Story So Far Read More Options for Material Selection June 14, 2018 Charles D. Schultz No Comments Disclaimer: This is the policy I follow for material selection. Your situation may call for a different decision. You should not adopt this pol...Read More Hardenability 102 June 7, 2018 Charles D. Schultz No Comments Material Grade in Gears Read More Hardenability 101 June 5, 2018 Charles D. Schultz No Comments Material Grade in Gears The reason not all gears can be made from the same material grade has to do with hardenability. We have long unde...Read More Parsing the Fine Print May 31, 2018 Charles D. Schultz No Comments If my last posting prompted you to look at a copy of a material cert, you probably noticed that the cert has much more information on it than just ...Read More What’s Your Angle? May 10, 2018 Charles D. Schultz No Comments Hulet self-unloader image courtesy of ASME. Interesting things happen when you start using “non-standard” gear geometry. As early as th...Read More That X Factor May 3, 2018 Charles D. Schultz No Comments Our international readers are no doubt chuckling over this silly, American “long addendum” terminology. The “civilized world” has long relied on a ...Read More Previous 1 2 3 4 5 6 7 8 9 10 11 12 Next
