The aim of our research is to clearly show the influence of defects on the bending fatigue strength of gear teeth. Carburized gears have many types of defects, such as non-martensitic layers, inclusions, tool marks, etc. It is well known that high strength gear teeth break from defects in their materials, so it’s important to know which defect limits the strength of a gear.
I'd like to share with you a vision of the future. It takes place in cyberspace, and it's coming soon to a computer near you. Whether you like it or not, and whether you're ready or not, the Internet is changing the way business is conducted.
