Gears with an asymmetric involute gear tooth form were analyzed to determine their bending and contact stresses
relative to symmetric involute gear tooth designs, which are representative of helicopter main-drive gears.
Tooth contact under load is an important verification of the real contact conditions of a gear pair and an
important add-on to the strength calculation according to standards such
as ISO, AGMA or DIN. The contact analysis simulates the meshing of the
two flanks over the complete meshing
cycle and is therefore able to consider
individual modifications on the flank
at each meshing position.
In co-operation with Voith, a major transmission manufacturer in Germany, Heller has developed a process that significantly enhances the productivity of pre-milling and gear milling operations performed on a single 5-axis machining center.
When Belgium-based Hansen Transmissions was under the ownership of Invensys plc in the late 1990s, the parent company was dropping not-so-subtle hints that the industrial gearbox manufacturer was not part of its long-term plans. Yet Hansen’s CEO Ivan Brems never dreamed that, less than a decade later, he would be working for an Indian company.
This article presents a new spur gear 20-degree design that works interchangeably with the standard 20-degree system and achieves increased tooth bending strength and hence load carrying capacity.
