This paper presents the geometric design of hypoid gears with involute gear teeth. An
overview of face cutting techniques prevalent in hypoid gear fabrication is presented. Next,
the specification of a planar involute rack is reviewed. This rack is used to define a variable
diameter cutter based upon a system of cylindroidal coordinates; thus, a cursory presentation
of cylindroidal coordinates is included. A mapping transforms the planar involute rack into a variable diameter cutter using the cylindroidal coordinates. Hypoid gears are based on the envelope of this cutter. A hypoid gear set is presented based on an automotive rear axle.
In 1964, a young and tidy Bob Dylan sang away in that infamous voice of his,
all nasally and grating yet wonderfully distinct, opining to the fervent masses: “The times, they are a-changin.”
