One of the current research
This paper presents two new techniques for
aligning and maintaining large ring gears. One technique uses lubricant temperature analysis, and the other uses stop action photography.
The gear hobbing process is a generating type of production operation. For this
reason, the form of the hob tooth is
always different from the form of the
tooth that it produces.
