The company esco, a technology partner for process digitization in the gear and cutting tool industry, is adding a technology module to its software for the Power Skiving process chain.
Widia recently launched the WCE solid end milling platform, delivering affordable performance and reliability for small to medium machine shops. The initial release of the WCE platform features WCE4, a four-flute geometry which combines advanced, high-performance features with a brand new, versatile grade offered at a highly competitive price.
Kennametal has introduced its next generation 3D printed stator bore tool for the machining of aluminum engine housings for electric vehicles. This latest version of the tool features a newly designed arm structure, a larger center tube made of carbon fiber, and a further weight reduction of greater than 20 percent over the original design.
Saint-Gobain Abrasives has introduced its new Norton Abrasive Process Solutions (APS) Program which was established to help customers determine the optimal grinding or finishing solution for the application at hand, ranging from simple to complex, off-hand or automated, and for metal fabrication, production grinding and virtually any abrasives operation.
Manufacturers need to measure and quantify the causes of unproductive time so they can optimize their efficiency. Machine Monitoring from Seco provides them with the data-driven knowledge they need to not only manage production efficiency, but also increase both output volume and product quality.
As a sustainability advocate and supporter of global sustainability goals, Sandvik Coromant has developed a set of internal goals called Make the Shift to set a new industry standard and raise the bar for sustainable business.
The complete Product News section from the January/February 2022 issue of Gear Technology, with new technology from Marposs, Solar Atmospheres, Mahr, Kennametal, Kapp Niles, Southern Gear, SMW Autoblok, WFL Millturn, Doosan Robotics and LK Metrology.
Broaching is an unusual machining process, because it has the feed built into the tool, which effectively makes it a collection of single-point cutting tools arrayed in a sequence. Analogous to the multiple passes of a shaper, a relatively new class of CNC tooling and programming allows broaching operations to be done without the need for a second operation, thus greatly increasingly quality control and reducing time, space and cost.
