For maximum life in carburized and ground gearing, I have been advised that fully grinding a radius into the root gives maximum resistance against fatigue failures. Others have advised that a hobbed and unground radius root form is best. Which is best, and why?
The honing of gears - by definition
- facilitates ease of operation, low noise and smoother performance in a transmission. Honing also contributes to
reduced friction in the powertrain. Both the intense cutting (roughing process) as well as the functionally fine- finishing of transmission gears can be performed in one setup, on one machine.
