The 2015 Gear Technology Buyers Guide
was compiled to provide you with a
handy resource containing the contact
information for significant suppliers of
machinery, tooling, supplies and services used in gear manufacturing.
I have outsourced gear macrogeometry due to lack of resources. Now I received the output from them and one of the gears is with —0.8× module correction factor for m = 1.8 mm gear. Since bending root stress and specific slide is at par with specification, but negative correction factor —0.8× module — is quite high — how will it influence NVH behavior/transmission error? SAP and TIF are very close to
0.05 mm; how will that influence the manufacturing/cost?
