Alongside the macro test parameters on tooth flanks for profile and tooth traces, surface
properties (roughness) play a decisive role in ensuring proper toothed gear function. This
article addresses roughness measurement systems on tooth flanks. In addition to universal
test equipment, modified test equipment based on the profile method for use on gears is
addressed in particular. The equipment application here refers to cylindrical gear flanks and
bevel gear flanks. The most important roughness parameters, as well as the implementation
of the precise measurement procedure will also be described under consideration of the
applicable DIN EN ISO standards as well as the current VDI/VDE Directive 2612 Sheet 5.
