should be considered.
stress will be discussed.
There exists an ongoing, urgent need for a rating method to assess micropitting risk, as AGMA considers it a "a very significant failure mode for rolling element bearings and gear teeth - especially in gearbox applications such as wind turbines."
The effect of the lubrication regime on gear performance has been recognized, qualitatively, for decades. Often the lubrication regime is characterized by the specific film thickness defined as the ratio of lubricant
film thickness to the composite surface roughness. It can be difficult to combine results of studies to create a cohesive and comprehensive data set. In this work gear surface fatigue lives for a wide range of specific film values were studied using tests done with common rigs, speeds, lubricant temperatures, and test procedures.
