Putting one's best foot forward is important for successful business communication. And successful business people know the "rule" of the game, what it say and do in business situations, to make the best impression. However, these rules change from country to country, and what is appropriate behavior here may appear rude to someone from Latin America, Europe or Asia To help you become more familiar with some of the different rules of engagement in other countries, Gear Technology spoke with three businessmen who have had extensive contact in various part of the world.
Two items of interest have crossed my desk in the last couple of weeks. One of them is a copy of a speech by Harry E. Figge, Jr., Chairman and CEO of Figge, International Inc., and the other is an article by Peter Brimelow in the July 19, 1993, issue of Forbes. The two items are directly related to one another, the Brimelow article being a response to the points raised in Figge's speech and in much grater detail in his book, Bankruptcy 1995: The Coming Collapse of America and How to Stop It. Both the speech and the response are well worth our attention.
The Hobbing Process
Gear Expo '93 - another trade show, another plea to send people and/or equipment out of town, away from the office or plant. Another bid to spend time, money, and effort. Oh, please! Hasn't anybody heard that these are the "lean and mean" '90s?
AGMA's Gear Expo '93 is expected to be at least 10% larger in terms of floor space than the '91 show, according to Joe Franklin, AGMA's executive director. "As of June 1, we have 80 exhibitors registered", he says.
Gear Expo '93, "The World of Gearing," is scheduled for October 10-13 at Cobo Conference & Exhibition Center, Detroit, MI. Hours are 9 a.m. to 5 p.m. on all four days of the show.
